Home > Think Tank > How to Fix Software Sync Problems by Removing OneDrive
Aug 5, 2026
OneDrive is a convenient cloud storage service that automatically syncs files between your computer and the cloud. However, in some cases, OneDrive synchronization can interfere with software that relies on local files, configuration folders, databases, or other application data. This may result in sync conflicts, missing files, duplicate files, or software that fails to work correctly.
If you ensure that OneDrive is causing a software sync problem, removing OneDrive from your computer may help resolve the issue.
Why Can OneDrive Cause Software Sync Problems?
OneDrive continuously monitors designated folders and synchronizes their contents with the cloud. This can sometimes cause problems for applications that frequently modify files, such as some social chat applications. For example, a program may encounter synchronization issues when:
  • A file is being synchronized while the software is trying to access it.
  • The same file is modified on multiple devices.
  • OneDrive moves files between local and cloud-only storage.
  • The application depends on files stored in a OneDrive-synchronized folder.
  • File permissions or file paths change during synchronization.
  • Multiple copies or conflicting versions of a file are created.
Steps to Resolve the Synchronization Conflicts between Software & OneDrive
Step 1. Back Up Important Files
Before removing OneDrive, make sure that any important files stored in your OneDrive folder are safely backed up.
  • Open File Explorer and select the OneDrive folder from the navigation pane. Check your files and copy important documents, photos, or other personal data to a folder that is not synchronized with OneDrive, such as Documents or another local drive.
  • Pay particular attention to files that display a cloud icon. These files may be stored primarily online and may not be fully available on your computer.
  • If necessary, right-click important files or folders and select Always keep on this device to download them before backing them up.
Step 2. Close the Relevant Programs
Before removing OneDrive, save your work and close applications normally. This helps prevent files from being locked or modified while OneDrive is being removed.
  • Close the software that is experiencing synchronization problems.
  • It is also a good idea to close other applications that may be using files stored in the OneDrive folder.
Step 3. Quit OneDrive
To stop OneDrive synchronization before uninstalling the application, you can unlink your computer from your OneDrive account.
  • Click the OneDrive cloud icon in the Windows taskbar notification area.
  • Click the Help & Settings icon.
  • Choose Pause Syncing.
  • Then click Quit OneDrive.
  • When the confirmation box pops up, select Quit again.
Step 4. Uninstall OneDrive
Once your files are backed up and your PC is unlinked, you can uninstall OneDrive.
  • Press Windows + I to open Settings.
  • Click Apps.
  • Select Installed apps.
  • Search for Microsoft OneDrive.
  • Click the three-dot menu next to OneDrive, and select Uninstall.
  • Remove the OneDrive folder located in C:\Users\[YourUsername.
  • Clean up leftover Registry Entries associated with OneDrive.
NOTE: If you prefer a more thorough cleanup, Wise Program Uninstaller provides an much easier way to remove OneDrive, because this tool can scan for and remove leftover files and registry entries after the standard uninstall process, helping keep the system cleaner.
Step 5. Check Software Status
After removing OneDrive, launch the software again to check whether the sync problem has been resolved.
Additional Options
  • You can first pause OneDrive synchronization temporarily and check whether the software works correctly without active syncing. If the problem disappears while synchronization is paused, this can help confirm that OneDrive is involved.
  • If you want to continue using OneDrive for cloud storage, you can instead prevent the affected software or folder from being synchronized.
  • Another option may resolve the problem is to move the affected software's data to a local folder while keeping your personal documents and other files in OneDrive.
OneDrive is useful for keeping files synchronized across multiple devices, but its synchronization process may occasionally conflict with software that frequently accesses or modifies local files. If a particular application is experiencing file conflicts, missing data, or other sync-related problems, backing up your files, unlinking your PC, and uninstalling OneDrive can often fix this problem.
How to Fix Apps Opening Off-Screen in Windows 11What Is That Black Box Flashing on Windows StartupHow to Stop Your PC from Waking Up Automatically in Windows 11
